I got the side panel glued in place . I then was able to build a cover for the gas tank. here is a few pictures .I not to far from finishing the fuselage .
I'm glad to get past the interior kit ,as it was not fun
I did a little work on the interior. I just need to glue the seats in place and the interior will be done.
I finally got the interior finished.
I hope it was worth all the work. I don't think I will ever do it again.
All and all , it came out better than I thought it would. Any way here is the final pictures of the interior. next all I need to do Is glue the front windshield in place and I will be finished with the fuselage , then I can start covering the wing , ailerons and flaps.
I got the windshield installed . It was a pain ,as it didn't fit all that well.
I am finally finished with the fuselage.
Now I can get on with the task of covering the wing and related parts.
I thought I had better check the fit of the wing before I cover it . After that I need to do some finishing sanding before I start covering. I'm beginning to think I will actually get it done . Here's some picture .
The wing needed a little more work. I need to get it done before I can start covering.
OK I finally got back on the Cessna.
I started covering the wing. I started on the bottom first. Next is the top and then the flaps and ailerons. Then I'll be ready to install all the servos and add the Decals. I'm going to try to get it ready before the next meeting.
Here's a couple of pictures finishing the bottom of the wing. Next it's on to the top of the wing.
Well I got the top of wing done . Next I need to cover the Flaps and Ailerons . I'm being to think I may finish it in MY LIFE TIME!!
