Post by kdoughty » Sun Jan 08, 2012 9:27 pm
The Cessna is starting to look like an airplane instead of a BOAT. :P
Here is some of the latest pictures.
Post by kdoughty » Thu Jan 12, 2012 6:57 pm
I did a little more to the Cessna. There is still a long way to go . I'm almost to the point I have to stop abd build the Stab and fin because they need to installed before I can sheet the upper fuselage.I have a couple of things to do like ,mount the tank and fuel lines , the muffler mounting blocks and sheet the front cowl.
Here is the latest pictures
Post by kdoughty » Sat Jan 14, 2012 10:51 am
Thanks
I've got a long ways to go. I hope I live long enough to " GET-r=DONE" :roll:
Post by kdoughty » Mon Jan 23, 2012 5:50 pm
Hey guys
I haven't got much done on the cessna.I got side tracked again.I put a trolling motor on my kayak. It was a present to me from me. I'm getting ready for my 75 th birthday. I did get the front top sheeting done and it was not fun. I hope the fun starts soon
Post by kdoughty » Wed Jan 25, 2012 5:15 pm
You never know tell you try.
I got started on the stabilizer.It has a lot of parts.It went together fairly good. It's ready to start sheeting. First I have to glue two sheets of balsa together. I hope it is easier to sheet than the fuse.
Here is some more pictures.
Post by kdoughty » Tue Jan 31, 2012 12:44 pm
I got one side of the Stabilizer done. While it's gluing. I started on the Elevator.I must have a long ways to go , because I still have a box full of wood. Anyway ,Here is some of the latest pictures.
Post by kdoughty » Fri Feb 03, 2012 6:24 pm
Well i finished the sheeting on the stabilizer.I got the elevaor built and sheeted.Now comes the FUN part. Carving the tips. I don't know if I'm a good carver or a bad carver. I guess we will find out.
Post by kdoughty » Fri Feb 03, 2012 6:27 pm
Here's another picture . I hit the wrong button.
Post by kdoughty » Tue Feb 07, 2012 1:12 pm
I finished work on the stab and the elevator tips and the.It wasn't as bad as I thought it would be. I sanded the leading edge of the elevator to a V. Installed the control rod and that just about does it now for the Stab and Elevator.Here is some Pictures.
Post by kdoughty » Tue Feb 07, 2012 1:15 pm
One more picture. It's starting to look more like an airplane.
