Page 1 of 2
SIG Kadet Senior "Sport"
Posted: Fri Mar 11, 2016 9:25 pm
by L82fly
Haven't flown in several months so I decided I needed something very "forgiving" to knock off the rust. I had this plane on the shelf for about 18 months and thought what the heck...
SPECIFICATIONS:
Wing Span: 78 in.
Wing Area: 1148 sq. in.
Length: 65 in.
Flying Weight: 8 - 8.5 lbs. (3629 - 3856 g)
Wing Loading: 16.0 - 17.0 oz./sq.ft. (49-52 g/dm2)
Radio: 4-Channel with 5 Standard Servos
Glow Power: .40-.53 cu.in. (6.5-8.7 cc) 2-Stroke Engine
.50-.61 cu.in. (8.1-10 cc) 4-Stroke Engine
Electric Power: Brushless Outrunner Motor (600-1100w; 500-800kv)
Busted it open on Saturday night 3/5/16
New in Box
Looking for damage or maybe dry rot from sitting on the shelf!
Started with the Ailerons on Sunday afternoon 3/6/16
CA those hinges!
Same game on other side and work on aileron control horns / rods
Wings with aileron servos and control rods completed, holding up freezer
Landing gear before tail surfaces? Didn't make sense but I followed the instructions, test fitted them to fuse then removed for mounting stab
Project Supervisor / Dog treat specialist
Have to wait for the Horizontal's epoxy to dry before continuing
As of Thursday Night
Glued on the vertical stab Tuesday night. Wednesday attached elevator, rudder and all rear pushrods. Have to pace myself...
Next update....Saturday since it will likely be wet!
Re: SIG Kadet Senior "Sport"
Posted: Sat Mar 12, 2016 8:03 am
by L82fly
Once these two guys get done playing with it this is the rubber band I'm going to use :lol:
rubber band.jpg (7.27 KiB) Viewed 52273 times
Posted: Sat Mar 12, 2016 2:33 pm
by L82fly
Latest Update....
Well the servos are all in, the switch, receiver and battery are kind of tossed in the fuselage until time to balance the model. I'm kind of hung up on the engine mounting which is forward of the suggested plans by about 3/8 of an inch. Playing with several options to get it closer to the firewall before heading on but won't let it hold me up to much since I want to get this bird in the air ASAP
Posted: Thu Mar 17, 2016 11:43 am
by L82fly
Engine issue was not that big a problem after I reviewed several options, Closing in on completion...
Just some details left...
Posted: Thu Mar 17, 2016 8:36 pm
by L82fly
All over but the flying...
Less than 2 weeks, it's a miracle :lol:
If the weather holds Sunday, maiden voyage. Hopefully better outcome than the Titanic...Did I say that outloud :o
Posted: Fri Mar 18, 2016 7:21 pm
by L82fly
Usta, Got me on the flying but I hope to soon remedy that :?
Now this one is off the board I need to get back to finishing the other four that I have less than 2 hours each to finish, what a bum :oops:
Posted: Sun Mar 20, 2016 12:59 pm
by L82fly
It' too cold out there!
Posted: Mon Mar 21, 2016 1:45 pm
by kdoughty
I think you are going to need a bigger garage L82fly !!!!!!!!!! :lol:
Posted: Mon Mar 21, 2016 5:51 pm
by L82fly
I've been lobbying for some of the available house, but my requests have fallen on deaf ears :cry:
Posted: Sat Mar 26, 2016 6:22 pm
by L82fly
Successful maiden voyage...Plane left ground, returned to earth undamaged lives to fly another day ;)
Sure is a floater :o
Couldn't beat today's weather!
